With your Diamond Membership, you can save on fuel costs by adding fuel stops to your route.
- Create a trip with stops and select your truck settings.
- Once you tap on 'Start Trip', a green bar indicating fuel savings will appear at the top.
- Edit your truck's fuel settings. Trucker Path will use fuel information from fuel stops along your route and calculate an optimized plan for you.
- Get a detailed view of the fuel stations you need to stop over and the amount of fuel you need to add.
- Trucker Path will incorporate these fuel stops into your trip.
Comments
1 comment
How can I get Trucker Path? I need to activate it for 6 months.
